Kmurphy213
Hey guys,
I am trying to Unroot my droid incredible but I am running into one slight problem I go to download the file which is in the sticky above "how to unroot your phone" the file is downloaded and saved just fine.
However I go to extract the zip file and It unzips to the "downgrade" folder which is saved to the desktop but then when i try to unzip the item within the "downgrade" folder it says that it is corrupt and I should try Installing it again....
I have tried this numerous times all ending in the same outcome.
Your help would be much appreciated!! I don't know if I am doing something wrong or are other people having the same problem
Looking Forward to hearing from you
