jdstone66067
Hi-
I recently switched over from a Blackberry Curve to the Samsung Galaxy s2. I like the phone and all the fun things it can do, but am having some beginners issues with it. Texting was so easy on the Blackberry and adjusting back to a flat screen is a challange. Do most of you use the keyboard app that comes with the phone, or are there other keyboard apps I can use. I downloaded a free trial of Smart Keyboard and have been using it. I really miss the BB shortcuts like holding down key to capitalize, etc.
My second question concerns the Voice Talk features. I like this idea, and it was one of the reasons I selected this phone. I set it up and it worked at first, but now I give the phone the command, it thinks about it and then goes back to the menu screen. I spent 3 hrs with T-Mobile trying to fix it with no luck- they recommend I upgrade to V4 to see if that would fix the problem but before I do that, I wanted to ask if anyone else has problems with Voice Talk.
Thanks so much!!
Thanks so much!!
