Hi
I have had the Desire for a few months now and normally charge it overnight and don't use it at the same time. I have just been away and used it for watching movies whilst it was charging and have noticed a lot of issues as the phone is almost unusable whilst its charging. I can hardly change screens or move between home pages and apps. It sticks on some options or judders and goes to things I haven't selected. It is OK again once off charge most of the time, but occasionally needs to be restarted.
I had just upgraded to the OTA Desire firmware upgrade from T-Mobile and was also using a new Micro SD card. Since I have returned I have changed the SD card to the one I was previously using and the same thing happens. I don't know if this was an issue before the firmware upgrade.
I normally charge directly from the mains using a HTC cable.
Is this normal or a fault with my phone? Is there anything I can do to improve it?
cheers
John
cheers
John
