Ace Advanced Hack Kit [Linux/OSX/Windows] attn1 2011/2012
___________________________
MAIN MENU | |
| Only ONE Menu Step to: |
1 - Hack Ace <----------------------------+ * S-OFF |
| * SIM Unlock |
2 - DONATE (Encouraged, but optional) | * SuperCID |
Free HTC goldcard generator | RevSkills | * Root |
http://www.eff.org/ | * Busybox |
o - Options Menu (Return to Stock, Flash radios, etc)
t - Toggle Flash Method - current method is fastbootRUU
q - Quit
[Select and press Enter]1
ro.product.version=3.13.720.2
This version of Android cannot use the hack kit at this time.
You can downgrade if you like, then rerun the hack step.
WARNING: THIS WILL WIPE DATA
[Would you like to downgrade? y/n]y
Download this RUU? [y,n]y
--2012-09-02 15:07:01--
http://tau.shadowchild.nl/files/PD98IMG-GB2.zip
Resolving tau.shadowchild.nl... 176.9.40.154
Connecting to tau.shadowchild.nl|176.9.40.154|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 259503624 (247M) [application/zip]
Saving to: `PD98IMG/PD98IMG-GB2.zip'
100%[======================================>] 259,503,624 221K/s in 39m 46s
2012-09-02 15:46:48 (106 KB/s) - `PD98IMG/PD98IMG-GB2.zip' saved [259503624/2595
03624]
a67daa6baa7ef085307593fef6329d14 *PD98IMG/PD98IMG-GB2.zip
Flash the downgrade RUU? [y,n]y
pushing rom to sdcard - this takes time please be patient.
1599 KB/s (259503624 bytes in 158.484s)
1503 KB/s (572752 bytes in 0.372s)
383 KB/s (19240 bytes in 0.049s)
673 KB/s (14475 bytes in 0.021s)
Starting stock recovery the first time to init....
Steps:
1. When you see the ugly red triangle, push/hold vol-UP and then push power to
start stock recovery.
2. When you get to the blue stock recovery menu, choose reboot and push power.
TacoRoot: HTC Edition v1
By Justin Case (jcase)
Presented by TeamAndIRC, RootzWiki and AndroidPolice
With great assistance from Reid Holland (Erishasnobattery)
TacoRoot: HTC Edition v1 is based on a vulnerability independently discovered by
both Justin Case and Dan Rosenberg (Rosenberg fist). I believe unrevoked and
AlpahRev were also aware of it.
Usage:
--recovery : For this exploit to work, you must have booted recovery at least on
ce after your last factory reset.
--setup : Setup the phone for root, must be done before --root.
--root : Root the phone.
--undo : Remove TacoRoot.
Rebooting into recovery, please press Volume+, Volume- and Power at the same tim
e, and reboot the system.
Starting stock recovery for the last time....
Steps:
Usage:
Rebooting into root.
allowing time for the rom to settle.....
Creating goldcard....
HTC android goldcard tool Copyright (C) 2011, Wayne D. Hoxsie Jr.
Original code by B. Kerler. Special thanks to ATTN1 and the XDA team.
Donations can be made to the Electronic Frontier Foundation:
http://www.eff.org/
or to B. Kerler:
RevSkills | We deliver mobile forensic and analysis software solutions worldwide
0+1 records in
0+1 records out
384 bytes transferred in 0.034 secs (11294 bytes/sec)
setting mainver lower for downgrade...
--set_version set. VERSION will be changed to: 1.31.405.6
Misc partition is "/dev/block/mmcblk0p17"
Patching and backing up misc partition...
