Problems with apps getting randomly deleted.
tcross8361
My first real issue with this phone. It keeps randomly deleting my apps. I've got all the apps that can be moved to sd, moved. I also have my apps organized into folders in the App drawer. The problem first happened when IMDB got deleted. It showed an icon that said IMDB and on it, it said SD. When I pressed it, it would say "Application not installed on your phone". The only way I can uninstall it is to go to the app drawer and press edit and press the minus sign. It won't show up in settings apps.
So now it has happened again with SoundHound. My only explanation is that the app has some how become missing and it shows it on the SD card only. I hope it doesn't happen to any of my games. I've attached a screen shot.
Any ideas?
Somehow those apps got deleted from the .android_secure folder on your external SD card. I've seen it happen on tablets running ICS. It may be because the sdcard wasn't fully unmounted from your PC before you unplugged the cable and some corruption happened!
If it happens to a game that has save points, is there a way to fix it without rooting and using Titanium Backup?
