sik00
Did not format mine either, slapped that puppy in straight out of the box, booted into cwm, tried a backup, and it hung at system backup. Seems to hang at the same spot every time. It gets through the boot.img backup, then freezes at system. I can do backups without any problems on the 2 GB.Thanks Bionic. I actually did not format them right off the bat. Like you, I just inserted and thought it would work. But it didn't, and the phone said to format it. So I did -- at least on the first two, using both the formatter program from sdcard.org and the phone. On this last card, though, I decided its not the disk, so I haven't even tried to reformat it.
I just tried it a few minutes ago for laughs. Booted into cwm and tried a backup. Told me there was an error with reading the sdcard. Then, without rebooting, I tried formatting in cwm and it said format complete. Okay. So I try backup again, and it froze at the same spot, backing up system. Pulled the battery, booted normally, and my Settings > Storage shows it mounted and working. Exploring the sdcard root folder showed me that the formatting was successful in cwm, because I had brand new folders with time stamps dated a few minutes earlier. Tried taking a picture, also a video, they both saved to the sdcard and playback just fine. The card just doesn't want to play nice with cwm.
Strange how your 32gb shows the same symptoms as my 16gb, yet your 16gb works, and mine doesn't.
