Help Problems with CWM - Did I root correctly?
Humvee
Hi everyone,
as you can see, I'm new here but decided to sign up to see if I can get some support for the problem I've been having.
I recently rooted my Samsung Galaxy S4 GT-i9505. It has TouchWiz but I changed to KitKat. I used a tutorial I found on YouTube. I have the link, but as Im new I cannot post it :/. Basically it got me to use odin to install (Is install the right word?) a .tar.md5 file called CF-Auto-Root-jftle-jftlexx-gti9505.tar.md5 . This rooted my phone and installed SuperSU. I heard that when you root your device you lose all of your data, but I didn't lose any of my data, and the root worked. I would firstly like to know if this is the right method and doesn't cause any problems.
Secondly, using ROM manager, I attempted to install CWM Recovery. It didn't work. I tried to follow tutorials, and also manually installing it using Odin. When I tried to install it using Odin, it said installation failed. In ROM Manager, I install CWM by following the instructions, when then I boot my phone into recovery mode, it just goes to Android recovery mode. Is this to do with the way I rooted it.
If someone could help with my problems I would be very grateful. Thanks in advance!
Humvee
Thanks, ill do that now and post the results
OK so I did that with the options Auto reboot and F.Reset time checked on Odin. In the top left it said recovery, then reset. What now? is my phone backed up somewhere? Sorry, Im quite nooby. Also I own ROM Toolbox Pro, which told me in order to back up I needed ROM manager pro.
EDIT: Nevermind, I worked it out. It says I don't have enough space to backup. Do I just need to insert and SD card?
