ballhands76
I've got a Droid X(stock Froyo 2.2.1) phone that, after being deodexed using xUltimate, suddenly has problems running Google apps. I don't get any options for adding Google accounts; the Market app crashes immediately after launch; the phone keeps asking me on reboot to accept Google's location services, etc.. I've successfully deodexed a Droid X phone before and didn't get these problems.
Looking at the logcat output for the Market app crash, I found this:
As another example, after agreeing to Google's location services' terms, I see this in the log:
Has anyone else seen this after deodexing? Would deodexing via a zip file work better?
Thanks in advance,
Raj
04-27 14:27:04.920 1263 1378 I ActivityManager: Starting activity: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.vending/.AssetBrowserActivity bnds=[245,640][355,758] }
04-27 14:27:05.014 1766 1766 E ActivityThread: Failed to find provider info for com.google.android.gsf.gservices
04-27 14:27:05.014 1263 1263 I ActivityManager: Starting activity: Intent { cmp=com.android.vending/.TosActivity }
04-27 14:27:05.232 1263 1620 D AccountManagerService: bind attempt failed for Session: expectLaunch false, connected false, stats (0/0/0), lifetime 0.001, getAccountsByTypeAndFeatures, legacy_hosted_or_google
04-27 14:27:05.240 1766 1766 D vending : [1] BaseActivity.completeGetAuthToken(): auth result is RESULT_CANCELED
04-27 14:27:05.248 1766 1766 D vending : [1] BaseActivity.onAuthTokenComplete(): null auth token.
04-27 14:27:05.271 1766 1766 W vending : [1] TosLoadAction.displayResults(): Could not check for TOS
04-27 14:27:05.271 1766 1766 E ActivityThread: Failed to find provider info for com.google.android.gsf.gservices
04-27 13:38:19.903 1263 1271 E ActivityThread: Failed to find provider info for com.google.settings
04-27 13:38:19.910 1263 1271 E GoogleSettings: Can't set key network_location_opt_in in content://com.google.settings/partner
04-27 13:38:19.910 1263 1271 E GoogleSettings: java.lang.IllegalArgumentException: Unknown URL content://com.google.settings/partner
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.content.ContentResolver.insert(ContentReso lver.java:585)
4-27 13:38:19.910 1263 1271 E GoogleSettings: at com.google.android.gsf.GoogleSettingsContract$Name ValueTable.putString(GoogleSettingsContract.java:5 5)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at com.google.android.gsf.GoogleSettingsContract$Part ner.putString(GoogleSettingsContract.java:126)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at com.google.android.location.NetworkLocationProvide r.setUserConfirmedPreference(NetworkLocationProvid er.java:539)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at com.google.android.location.NetworkLocationProvide r.userConfirmedEnable(NetworkLocationProvider.java :547)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at com.google.android.location.ConfirmAlertActivity.o nPause(ConfirmAlertActivity.java:63)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.app.Activity.performPause(Activity.java:38 42)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.app.Instrumentation.callActivityOnPause(In strumentation.java:1190)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.app.ActivityThread.performPauseActivity(Ac tivityThread.java:3409)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.app.ActivityThread.performPauseActivity(Ac tivityThread.java:3379)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.app.ActivityThread.handlePauseActivity(Act ivityThread.java:3362)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.app.ActivityThread.access$2700(ActivityThr ead.java:129)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.app.ActivityThread$H.handleMessage(Activit yThread.java:2118)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.os.Handler.dispatchMessage(Handler.java:99 )
04-27 13:38:19.910 1263 1271 E GoogleSettings: at android.os.Looper.loop(Looper.java:143)
04-27 13:38:19.910 1263 1271 E GoogleSettings: at com.android.server.ServerThread.run(SystemServer.j ava:595)
Thanks in advance,
Raj
