problems with importing contacts
mcleod90
guy at att store put my sim card in from my iphone 3g and none of my contacts showed up, he played around with it and got it.
but when i wanted to go add a picture to the contacts it wouldnt allow me. i took the picture, went to set as, clicked contacts and then none of my contacts were there.
any idea on what i can do to fix it or what i am doing wrong? im sure there is a simple solution to this.
He probably copied your contacts from the iPhone to the SIM card. The SIM card won't store pictures. You will have to copy from your SIM card to Captivate's memory and then it will allow you to add pictures.
