Root Problems with incredible root/Mac
Hi there...
I'm really new/slow with this, so I apologize if I use incorrect terms or anything like that. I rooted my phone last week, did a nandroid backup immediately, and then tried to get rid of some of the Verizon apps with incorrect instructions. I was afraid I may have messed something up so I did the nandroid restore and left it for a few days. I decided to tackle disabling some of the Verizon apps this evening and am running into some issues. (Also, my % of time without a signal went WAY up after rooting before I did absolutely anything else to it... has this happened to anyone else?)
I have Snow Leopard and followed these instructions to set up everything in terminal:
Download the Android SDK for Macintosh
- Extract it
- Open up a terminal window
- type: pico .bash_profile (this will create a .bash_profile)
- type the following in the new screen: export PATH=$
{PATH}:<sdkfolder>/tools
- Hit CNTRL + X
- Hit Y (for yes to save)
- It will return you to the terminal screen
If you are not familiar with SKD, I really wouldn't recommend you use it.
Another vote here for Titanium Backup. It's free on the market. Just install that and it will remove the app's for you.
Ok, so I don't have the paid version of Titanium yet, won't for a week or so more. What is the exact process to do this in the free version, as I see "uninstall" and "delete" on many apps? Will uninstalling any of these Froyo Apps (Amazon MP3, CityID, VZNavigator, etc.) adversely affect my phone? Or is there a way to disable them and move them to my SD card and/or laptop so that I still have a copy of them if they're for some reason ever needed?
Also.. will I be able to do things with ROMs and boot animations, etc. without being able to use SDK? (SKD? so confused *sigh*)
There should also be an option to "freeze" the app. so that it doesn't run or show up. It doesn't delete it though.
