sometimes i receive messages and sometimes i dont get them. and other people sometimes dont get mine either, is anybody else having this problem???
and how can i fix it?
In your messaging settings (open messenger>menu button>settings>scroll all the way down till you see a check box for "Failure Notification" (show if message cannot be sent)
Make sure that is checked.
Now if your message cannot be sent, it will let you know.
ALSO, while your in the settings, look to see if AUTO retrieve is checked.
It has to be checked so it can retrieve messages automatically, if not it can miss some of them
Well good luck and if this works, there is a thanks button right underneath muh. = D
