Root Problems with mounting
scheng12
I just flashed the new Cyanogen but I'm having trouble mounting now. Whenever I try to move a file over it gets stuck, and when my display goes to sleep it won't wake up unless I pull the battery. Is this a ROM problem or something else? It was working fine a few days ago
So you are saying this happens?
You mount the SD card as a USB storage device
Start transferring a file from your computer to the SD card
Droid screen times out and turns off
File transfer freezes and Droid won't wake up
Is this correct?
It doesn't time out or turn off by itself. The file transfer freezes and the droid is still awake. But if I put it to sleep or it times out, it won't wake up again
