Help Problems with My ZTE warp, can anyone help?
My phone is rooted, and running Warp Cream Sandwich 1.6.
I rooted and installed WCS after these problems started to try to see if it would fix it but not fix.
When ending a call, it will not completely end. The screen will say call ended and turn red, but i have to go into applications > Dialer and manually force close to end a call.
Also, not receiving any calls or text messages.
Anyone know how to fix this?
I have already tried doing hard master resets and it still doesnt work properly
Did the wipe, had the same issue until i decided to flash the kernel, once i did that, it is working perfectly and a lot faster. Thanks!
Do you have Titanium Back up? I had a similar issue and did a restore on just that app ( I guess would be your dialer?) That worked for me.
