Help problems with network internet not working
hi i got three network unlocked so i could use my orange contract simcard. wifi works fine, however the network internet does not work. Ive clicked on orange 3g, orange, and even though it says that the network is registered still doesnt work. hoping someone could help with this thanks.
MMS Settings
APN: orangemms
Proxy: http://192.168.224.10
Port: 8080
Username: Orange
Password: Multimedia
Server: http://mms.orange.co.uk
MMSC: http://mms.orange.co.uk
MMS Proxy: 192.168.224.10
MMS Port: 9201
MCC: 234
MNC: 33
APN type: mms
Orange internet Settings
APN: orangeinternet
Proxy: 192.168.071.035
Port: 9201
Username: <not set>
Password: <not set>
Server: orangeinternet
MMS Port: 8080
MCC: 234
MNC: 33
APN type: <not set>
Do your APN Settings look like that?
Settings -> Wireless & Networks -> Mobile Networks -> Access Point Names
when i click apn it is a blank screen, but when i click on it it says either add (or set i think) new apn or reset to default. the info you given me should i click on set new apn and type in that info?
Yeah, you'll need to do it twice, entering the in the top set for MMS, then create another APN using the bottom set of info for Internet.
Does that make sense? I can make a screenshot showing you mine if it makes things easier?
Here you go.
Initial APN Screen -
Internet 1st Page -
Internet 2nd Page -
MMS 1st Page -
MMS 2nd Page -
Is that ok?
do you have to enter the mms settings first or does that not matter? i entered the info from your first post, but i created the internet settings first and then mms. the internet still doesnt work, on the top bar of the phone it keeps switching to 3g to h with both arrows pointing up and down
It doesn't matter which order they are done in no, the phone knows which is which thanks to the info you put under APN type.
This is my Orange APN, looks a bit different to El's:
APN: orangeinternet
MCC:234
MNC:33
APN Type: default,supl
Everything else is blank.
