Help Problems with reception
amblue
I've recently had a lot of problems with reception on my thunderbolt. I've had 1 to 0 bars at times while I was inside and generally in areas I previously had good service with other phones. Does anyone know what might be causing this problem?
If you just started having issues then might be the towers. Cant compare past phones with receptions of your current one. Some phones has great reception while others has poor. IF it doesnt fix after while call verizon. Best I can tell ya.
