Root Problems with roms and clockwork.
dfine06
Ok so im having some weird problems i havent ever had before while using clockwork and loading new roms. First off i tried running petes new bb. It gets stuck at the moto sign after loads for over about 20 minutes. Then if i try to switch to another rom like say cyanogen 5.0.6.2 from my previous rom which is jrummy's remix it loses the market so i cant even load any apps etc. What is with these weird problems lately?
With petes bb do i have load sprecovery or will it work with clockwork?
I had those same problems after a few different rom loads. Download a cache cleaner. Mine cleared 270 something megs of cache, and I haven't had the problem since.
is that a market app?
yea its been weird with the no market on other roms all of a sudden. my phone has never bugged out before until lately and i havent even done anything.
I'm assuming that wiping /cache through Clockwork does the same thing. And you don't need an app for that. :)
CacheCleaner is free and works fine for me. I never knew of the RM one and tried it out, and it well FC'd on me :rolleyes:
If you are downloading a CM ROM (not a themed one like JRummy's) then you have to check the Google Apps options, if you don't check it then there will be no Google Apps on your phone, this includes the Market.
