Root Problems with Rooting & Making Back up
Hello, I'm new to Androids.. just trying to delete the crapware.. got the phone rooted, and downloaded the Tianium Backup App.. said something was wrong with busybox...so downloaded that app.. or an installer app, try to download but it says there is either not enough space on SDcard or SDcard is mounted.. there is enough space without the SCcard.. I'm not sure what I'm doing wrong.. need a step by step guide of what to do from here.. all I want to to get rid of the crap I'm not going to use. Please help. Thank you.
*Does it matter that the Titanium isn't the pro ver?
First, how did you root? Super One Click runs a check for BB and installs it if it's not found. And did you re-boot after rooting? You have to re-boot for changes to take effect.
About Titanium BU: I would splurge and buy the Pro version.
I used super one click and rebooted.. so just uninstall titanium back up and get pro and it should be right there and I can delete the unused apps? Do I want to have the SD card out anytime I mess with the unused apps or does it not really matter?
