Could be a dirty or damp screen, bad digitizer(touch screen control) or software issue. If the screen is clean try doing a factory data reset by going to settings-backup reset-factory data reset. This will reset your software so make sure you have anything you want saved backed up to your PC or the cloud.
Been experiencing some problems with my S4 Mini.
Occasionally the screen is flickering and opening applications on its own without touching them.
Can someone explain what is going on?
Is this a common problem?
Grateful for any assistance.
Thanks for your response.
EDIT: I plugged my phone in to my laptop and opened the files. Found 2 folders: Phone and Card. I opened each of these in turn and copied all the folders contained. I then copied each folder to my laptop.
Is that sufficient?
Should I be doing something more to ensure I get ALL my files, videos, pics etc from my phone backed up?
