Help problems with swype
rbk21
so ever since i did the update there is a REALLY annoying bug on swype.
when i double tap a word to highlight and correct it instead of the word choice window i get a menu asking if i want to cut, copy, etc...i then have to press the back key and the swype key to get to the alternate word choices.
it makes texting super slow and clunky and i haven't found any way to disable this.
oh also, when i get updates for applications i can no longer just update them all at once, i have to go thru each one and press "update" and then "accept"...is there anyway around this?
any suggestions would be greatly appreciated.
i am really hating this update, the phone is super slow and buggy, its a big step backwards....is there any word on when they may fix/improve gingerbread? or is there anyway for me to go back to the older version?
it has turned my phone from something i really enjoyed to something i want to use as little as possible.
Just press on the word you need to correct once and then the alternate word choices will pop up.
You should have an "Update All" box on the top right in the Market under "My Apps". If it isn't there you may want to try clearing the app data/cache for the "Market" app.
hey, when i press the word once nothing happens, only the lil arrow that allows me to move the cursor to a different part of the word/message.
pls help this is incredibly frustrating.
also re: the update thing this is less frustrating but the update all is grayed out.
thanks.
So Swype suddenly quit working and directly me to upgrade to the latest version. I've tried several times but am caught is and endless licensing loop that installs and then says a newer version is available.
Rinse, repeat.
thanks.
If you click on the word (once quickly), the arrow comes up, but the list of possible words also comes up right over the keyboard.
