rocktonic3
so here's my problem - i replaced my front glass and digitizer after dropping it on the driveway. since finishing, while the touch interface definitely 'works', some things are totally off. for example, i can't pull down my window shade, and often if i try to select a menu item, the wrong menu item is pressed. basically it seems like the screen needs to be recalibrated but as far as i can tell there's no way to do this.
since i replaced the glass, i've tried reflashing cyanogenmod, restoring to sense, resetting to factory, etc. not really sure what else to try and would really appreciate some help!
thank you!
thank you!
