Root Problems with widgets not loading due to A2SD+
lob
I am running Modaco's Desire r8 ROM with A2SD+ and When I reboot my phone all my widgets that are not default to Sense wont load and I have to remove them and then add them again.
I don't really know, but I think this may be because the widgets have been forced onto the SD. Is that the problem?
if so, is there a way to chose which apps get forced to move to the SD?
Thank you for your help.
:D
With a2SD+, I have no issues on R8 or other roms. Are you definitely using the a2sd+? or are you using a2SD in froyo -"move to SD card" in manage apps?
All my widgets are on SD card and work fine.
I had that problem using the mod install app, if you moved certain widgets to the sd card they would stop working.
No such problem with the apps2sd+ all keep working fine.
Hmm.... Strange....
I'm reluctant to restart my phone to see if the issue still occurs though.......
Ahh.... the joys of rooting!..........
