Help process.android.media
I recently (past few weeks) started getting the android.process.media has stopped unexpectedly error.
Over the past two days I've had two small updates, but they only seemed to update the market.
Not sure if an app that I installed is causing my media error or not. There doesn't appear to be any negative effects other than the message itself.
Is there any way to narrow down the cause of this?
Anyone else out there having the same problem?
As far as media goes, I'm using Google Music, and as I said, it still works.
Any tips would be great. --- researching this error on Google, I have already cleared the data from the media app and cleared cache as well.
