The last app I downloaded was called SmorgWhite its a open home theme but I did even was it yet. what I did was make folders on my sdcard for ringtones and notifications from the pc and then when I was done turned the phone off and back on while it was still connected to the pc
This happened to me twice in a week. Have to factory reset both times.
I am currently without a phone until I get it reset again. Is this a problem
with HTC? Not only does acore die but several other google processes. Every time
I try to make a call it dies and will not let me.
I did download and try to use Skype Light. Maybe that was what happened last time too. Does it cause problems? How can you trust anything you download?
Did you try a battery pull during the boot fail?
MyBackup Pro or Titanium.
I seem to recall that this may have something to do with Facebook syncing. If you have an Eris, do you have Facebook contact syncing set up? What happens if you go into settings->accounts & sync and delete the Facebook account? (I could be remembering this wrong, but, if this doesn't help, it's easy enough to set up again.)
As for which apps are taking up internal storage, settings->applications->manage applications. Allow the list to refresh, then menu->sort by size. What is the largest app and how large is it? If you go into the larger apps (by tapping them) and tap the button "clear cache" (if they have one), does that help increase free available memory?
