Accessories Proclip for incredible is from heaven
jawse
I jut got my proclip for the incredible with the built in charger so when you slide it into the holster in the car it automatically charges. It is awesome and slides in so nice. Its so great I think im going to order the proclip and the bedside stand and use it for a charging cradle since you can get it with the charger built in and you can turn it in any direction so you can have your phone upright. Its awesome head over to the site and check it out. A bit pricey but worth every penny as you can get a car attachment designed for you car so it fits perfect. ProClip Mounting System
...looks like it won't fit the phone with a case and the adjustable holder would cover the charging port...
It will not work with a case on. However the adjustable holder has the charger build into it. No need to do anything, just dock it and it is charging.
I too have the proclip for my car...
And yes, you do have to remove any case you might have (I have the innocase II).
But, as I am in the car about 2 hours a day, this is a PERFECT car dock for this phone.
Charger built in to the dock makes this the best dock I have owned.
Pricey, yes.... but well worth it.
Lego!
has anyone found a coupon for pro-clip at any point? if i could find a discount for these i would definitly buy one.
