Help product registration/Phone tracking?
luke318is
Hi there. was just wondering if anyone has found a place to register their phone with samsung. also wondering if there is a built in remote tracking or remote lock option for lost phones. i thought i remembered seeing an option for it somewhere
Menu>Settings>Location and Security> Tick the box saying remote functions then you should be prompted to set up a samsung account IIRC. Once you have set this up you can log on to the samsung dive website to track, wipe and retrieve call logs.
i cant get DIVE in AUST and had trouble with turning samsung things off/on but a factory reset fix that. (gotta check out seekdroid)
