Root Programming menu
prj
I've installed the Nonsensikal ROM. With HTC Sense I would dial ##778 to get into the programming menu to change my SID numbers. ##778 or ##PROGRAM is not working on this ROM to access that menu.
Anyone know how to get in there?
Interesting. I programmed a bunch of SID numbers in my phone with Sense installed. Do you think it held those numbers?
I believe that programming like that is held, as long as you do not update the radio. None of the Froyo ROMs do that, so you should be all set.
If you do need to reprogram anything, you can nandroid backup, install (or restore) one of the ROMs with the HTC frameworks - PlainJane, Ivan's, the xtrROMs, etc. - do the programming, and then restore the Froyo ROM.
you can use the following to activate the phone like *228, 2 (update roaming)
*22899
the other way, to update your program settings would be to flash back to a 2.1 ROM, do your programming ##PROGRAM, then make your changes, and then flash to the new ROM, those settings stay baked in.
