Root Project Elite v5! (ASOP Gingerbread)
GirLuvsDroid
Android Expert
PE Gingerbread is OUT! It's from AOSP source -- not CM based, although some CM fixes were utilized. Allows status bar/pulldown panel text color changes on the fly and there's so much more. See below for the Changelog.
Download here: Project Elite • View topic - Project Elite v5! (ASOP Gingerbread)
Download and more support also available here: {ROM RELEASE}ProjectElite v5 Gingerbread ASOP - Droid Forum - Verizon Droid & the Motorola Droid Forum
_____________________________________________
**A FULL WIPE IS REQUIRED**
wipe please and everyone read this please. many phones still have small issues with 3g even the nexus s so if you lose 3g go into airplane mode and back out it will come back but it should rarley happen. Also this was built for the droid which gb was not intended for so alot of lib and stuff were used t make fixes although it is stable please remember that
If you notice your 3g is gone go into airplane mode and back out and it will come back.
Changelog Version 5 (2/23/2011)
Note: Anything without credit was done by actngrezy and mojo_droid
  • added hot reboot to the reboot selections (credit mojo_droid, actngrezy, raidzero)
  • new lockscreen choices (rotary, revamped rotary, lense, and sense) (credit Sven Dawitz, Stefano Pignataro, mojo_droid, actngrezy)
  • battery percent on lockscreen (credit Robert Burns, mojo_droid, actngrezy)
  • New Redesigned Elite Options
    • Change overscroll glow color
    • remove clock from status bar option
    • persistant status bar date
    • lockscreen custom carrier text
    • custom lockscreen colors
    • choose lockscreen background
    • check for ROM update option
    • Ability to install kernel option (supports clockwork,spr and possibly rzr but rzr not tested with this feature)
      • when you choose a kernel your phone will reboot an automatically install the new kernel
      • Thanks to gflam from sourcery with help for script to install update.zips from recovery
    • New boot animation previews
    • remove battery icon option
    • Battery Percent option (credit Sven Dawitz, mojo_droid, actngrezy
    • hide lockscreen text
  • custom notification and status bar colors
  • notification power widget(Galaxy S) (credit cvpcs, mojo_droid, actngrezy)
  • extended power widget (credit rmcc, mojo_droid, actngrezy)
  • volume button music controls (credit cvpcs, mojo_droid, actngrezy)
  • camera button play/pause (credit cvpcs, mojo_droid, actngrezy)
  • lockscreen music controls (credit cvpcs, mojo_droid, actngrezy)
  • new stock bootanimation
  • new raidzero kernels (default 1.1GHZ)(credit: raidzero)
  • new kernel from pete (credit: pete)
  • new gesture options in music app and mms app (credit Jason Asher)
  • Restyled music app and forward-port of features (credit Jason Asher)
  • New music widgets (credit Jason Asher)
  • reflow web content
  • led while screen on
  • extended app controls
  • updated market 2.3.2
  • updated carhome
  • updated titanium backup (3.7.1)
  • phone goggles (credit David Bidorff, mojo_droid, actngrezy)
  • long press back to kill app (credit cvpcs, mojo_droid, actngrezy)
  • Rotary answer in Phone app (credit James Peterson)
  • Allow SIP User-Agent configuration (credit arcee, mojo_droid, actngrezy)
  • Updated FLAC support (credit cvpcs, Cyanogen, kroot)
  • GPS fixes (credit CodeAurora)
  • Droid specific gingerbread fixes (credit to cvpcs,mtwebster,nadlabak and the rest of the CM team)
  • working video camera fix (credit cvpcs)
  • openVPN support (credit James Bottomley)
  • quick unlock (credit gsarrica, mojo_droid, actngrezy)
  • and more...
  • if we forgot to credit someone please contact us so we can update the changelog
  • A special thanks to everyone who works on cyanogenmod, for all the work they do, all the fixes they find, and the community they helped build
_______________________________________________
Congratulations actngrezy and mojo_droid!!
Thanks so much PE Team. I have been waiting for then new update for awhile now. v5 puts the prev v4.2 to shame (lol not dissing v4.2) Having some scroll problems while in keyboard mode. only with certain apps though. other than that runs great. keep it up guys
ok... problem with the Add-On Ringtone pack... when u download it says needs to restart. ok but now i am stuck on the boot animation. just keeps playing over and over... tried restarting but the same thing just happens
DL-ed and Flashed last night, so far I love it, super smooth, super fast, and all around amazing. lol All the new stuff is great. Thank you PE Team & Everyone involved for all your hard work. <3
Quick question, is there a reason you got rid of the transparent notification panel? Not a big deal but definitely something I miss. Other than that I'm having no problems so far. Loving the new features and the tried and true speed of PE!
I was very happy to see this. PE has always worked best with my phone. I've been bouncing around between SS5, Liquid GB, and UD3, trying different launchers, and nothing works as well as PE4.2 did. I'm hoping this one is just as good. So far it seems nice...
Anybody else having issues with the phone running hot after flashing this ROM? I was close to 55C before I turned it off to cool it down. I'm at work so I have no signal to download a new kernel, but I flashed a Chevy kernel that I had on my SD Card and it seems to be running ok now. Just curious if my phone is the only having this issue.
Another thing I noticed was that I can't underclock the minimum speed below 600 ... even if I set it to something below that number, it will still show at 600.
I might just need to reflash and start over to see if that fixes the issues.
my phone was running hot w/ the stock kernel as well. switched to a diff rz kernel and temps seem fine for the moment. so far this rom is blazing fast! great work devs!
getting a force close on my root explorer app, same thing was happening with LGB 1.3.
It's working fine on CM7 nightlies. Started with a full wipe and all that. Other then that it is a very fast ROM and so far very stable too.
did you have the phone on the charger? I know it will stay at 600 when on the charger. I have noticed when I had the nightley rom on my phone it would go no lower than 400 snd could have it set to 250. :confused:
Make sure you have the most updated version of Root Explorer. It's working great for me and the ROM is running very cool on the 1.1Ghz LV RZKernel.
Thanks GirLuvsDroid, that did the trick. For some reason not all my apps were showing up in my apps section in the market, had to restore some of them with TB and reboot and now they are all there and with updates available.
I did have it on the charger. I had no idea it did this, probably because I never looked. Thanks!!
I've not been happy w/ any of the GB ROMs out there so far, but I'm probably going to give this one a try. Are there any major issues/bugs w/ this ROM?
Are all sensors/radios/nav/vidcam/3G/etc working?
-G
Gettin ready to DL and install..but its been a while since ive upgraded roms(lfy1.95 currently)
-how do you keep your text messages when wiping? im using tibu and im not positive that im backing up my text messages correctly
SMS Backup & Restore from the market.
-SNT
I flashed this yesterday at work. Great rom. Some issues I have seen so far are LP 3D drawer not working right. It just won't scroll right. I can scroll down, but an up scroll just takes it back to the top of the app drawer. No big deal, just not using the 3D drawer now. Juice Defender doesn't show the shield in the widget. Last night it was saying "error" above the widget. Went to the 1200 kernal; this thing is fast and snappy. Great rom. Been a loyal Liquid fan for months now, gave PE a shot on the previous version. Ran that for a day and then saw GB was up on the sight. Thanks for all the work that PE and his dev friends put in! I plan to donate, hope everyone else does too.
I am more than impressed with this ROM. I especially like the built-in ability to flash a different kernel. And then, when v5.0.1 was released last night, all I had to do was click on the update ROM option and within 3 minutes the newest build was on my phone. Fantastic work. All we need are some slick themes (like Blacked Out or NexTheme).
And for those of you experiencing high CPU temps, try flashing one of the LV Raidzero kernels. It worked for me.
Great, v5.01 release last night? Haven't even been to the site today to check. Looks like I got an update to run!:D:D
Two themes are out so far:
[THEME] RENOVATED for PEv5.0 - Droid Forum - Verizon Droid & the Motorola Droid Forum
[THEME] Black Chrome - PE v5.0 Droid 1 - Droid Forum - Verizon Droid & the Motorola Droid Forum
