EHokie
So...Bump? Has anyone actually uncovered anything? It's weird to see this problem persist for so long.
I imagine we would have heard if someone had uncovered something. You aren't the only one who wants MMS.
Has anyone tried this?
I appreciate the clarification between AOSP and Sense, I was just curious as to if the changes made to the MMS apk could be compared to the regular apk on that ROM, to see which fixes were applied - for any hints.
Just to clarify everything. It's going to take someone with a solid handle on mms in the aosp code to fix mms. No mod/hack/xml swap will fix mms. It will take code mods
Do you have any idea why it works for the One V but not for the Evo V?
I know there was a fix that got MMS working for an evo 4g ported to Virgin mobile running ICS. It is also a 4g wimax phone. I would assume there would be a lot of similarities between the two phones as they are both HTC wimax 4g phones.
Its not 4G
It's not 4G? Well there goes our only lead. >.<
This is probably true, but in order for them to use that phone on Virgin Mobile, they would have needed a donor phone (a VM's phone information). Since this is the first and only real 4G wimax phone on VM, we cannot compare to any other circumstances.
Donor phone was for MEID and ESN, The APN settings and everything still needed to be changed to the correct values for Virgin mobile and the mms.apk needed to be changed in some way. The phone specific stuff that was needed from the donor phone doesn't really have anything to do with the MMS. I would be willing to bet that there is some useful information to be had there.
But it was never setup as the evo v. I.e. sprint VM. And sprint 4g.
anybody wanna look at this http://forum.xda-developers.com/showthread.php?t=1491189
no... check my thread... people here on the evo v forums on my thread for paranoid android have mms working... this is a sprint evo 3d rom but mms is working on evo v virgin mobile...That's MMS for sprint.
here is the only line of code with virgin mobile mentioned found in the apns-conf.xml used in the paranoid android rom... there are many other lines with sprint/boost/metro/cricket/mobipcs/etc... if needed, i can post the full file up...
<apn carrier="Virgin Mobile US" mcc="311" mnc="490" apn="0" mmsproxy="205.239.233.136" mmsport="81" mmsc="http://mmsc.vmobl.com:8088/mms?" port="" type="mms"/>
