rhino889a
Android Expert
You may have heard of Pimpmyrom
It will install initd to your system
Initd will be needed to run some if our scripts
http://forum.xda-developers.com/showthread.php?t=1933849
https://play.google.com/store/apps/...oogle&utm_medium=organic&utm_term=pimp+my+rom
Bootbuddy
http://androidforums.com/rooted-dev...t-scripts-sdcard-safe-alternative-init-d.html
Another tool we may use is a scriptmanager. It use to install bootbuddy and install or run certain types of scripts
https://play.google.com/store/apps/...um=organic&utm_term=script+manager+play+store
Terminal emulator
https://play.google.com/store/apps/...251bGwsMSwyLDEsImphY2twYWwuYW5kcm9pZHRlcm0iXQ.
Benchmark tools
https://play.google.com/store/search?q=benchmark&c=apps
Bootbuddy
Terminal emulator
Benchmark tools
