Proper Kernel/Build?
ch229151
Member
Kernel:
3.0.15-I777UCLE5-CL652575
se.infra@SEP-74 #3
Build:
IML74K.CLE5
The reason I'm asking is because I had quite a difficult time getting ICS onto my phone. The official update bricked my phone. I then tried using an Odin one-click, but that failed twice, but only after reaching 90%. Before giving up, I tried the official Kies update again and that completed successfully. Im relatively new to Odin one clicks and the like, so I wasn't sure if that flashed my phone with some rooted version of ICS or whatever other wizardry it used to help the process.
Most likely what happened was you failed to complete the flash with Odin so when you plugged into kies it offered you an emergency recovery which would bring your phone to the current firmware. CLE5 is the current 4.0.3 stock version for the i777, so you're good.
