Accessories protective case for 3500mah extended battery?
I apologize if this has been discussed already but does anybody know where I can get a protective case for my incredible carrying a 3500mah extended battery?
I want something cheap if i can...
thank you
Sorry, but i have not seen any actual case made. The problem is, is that the 3500mAh batteries and associated cases, are made by somewhat "random" makers, and would be hard to guarantee a fit.
The extended battery from Seidio has a special case for it, but i could not recommend Seidio any more as far as i could throw them.....
Pick up a silicon case and cut out the back. When I was using the Seidio 3500 that's what I did and it worked great an dwas very easy . I used scissors but it would have turned out better with an Exacto Knife .
I don't know how much the Seidio case is that fits there battery but I ahve a Seidio Innocase for the stock back and it's the by far the best case I've used and the Seidio 3500 is by far the best extended battery . So I'm sure there extended case is a good buy
