I've been using my new S2 for about 2 months now. A couple of days ago the proximity sensor started acting weird: when calling, it turns on (so the screen is locked) no matter what I do. Whether I'm holding my phone to my ear or just put it down on the table, the screen goes black. After that, the phone wont respond to anything anymore, except the volume button. Turning on the option 'power key ends calls' also works (and is, in my case, the only way to end the call on my end, besides removing the battery).
During/after the call, there is (afaik) nothing that can remove the screen lock, except for the HandCent Popup (so 'Enable popup' in HandCent must be ticked, the notification only won't do it). I can still receive calls, but can't answer them. I can still plug in my headphone and MortPlayer will start playing.
The latest change I made to my phone was saturday: an update to Dungeon Defenders. I haven't installed or updated anything since. Yesterday, wednesday, the error occurred for the first time.
In short: when calling, the Proximity Sensor kicks in, the screen locks and is only unlockable by receiving a text message with the HandCent popup.
Does anyone know a solution? Is this a software or hardware problem?
I already found that checkbox. Haven't found out if the Prox Sensor is actually useful (ie. if calling without it will accidentally end my calls), but I'm guessing I'll notice soon enough. (And even if I'll never hang up by accident, if my problem is hardware related, I'd like to know now.)
