I know that android 2.2 does not have proxy settings. I just wondered if Gb might have it or weather there is an app that will allow it. I would like to access t'internet via the work server.
You could try Firefox - you can set proxy settings in that :
To set a proxy server in Firefox 4 beta for Android:
Type "about:config" in the address bar and press return.
Type "proxy.http" into the search box on the about:config page.
Tap on "network.proxy.http" and type the server name into the text box.
Tap on "network.proxy.http_port" and type the port number into the number box.
