Root PS3 six-axis Wii mote X-Box 360 controller
scerini
Member
Anybody know if these will hook up on TU? I love playing emulators but overtime I feel its going to wear on my phone and would rather be using a controller. Any tips or advice on this one?
there are apps for the PS3 and the Wiimote, but the Bluetooth library on the phone is not compatible, you gotta hope they can get CM7 successfully ported before they will work
I believe if you download the "Sixaxis Compatibility Checker" on market, it will tell you that the Transform Ultra is compatible with an original PS3 controller via bluetooth. Unfortunately I don't have a PS3 controller to test it out. If you have one available to test this theory, let us know the results of said test.
All the best,
Aanairai
I have a Rooted Samsung Transform Ultra. I'm trying to find out if I still have to do Something to it just to get sixaxis controller working I have my own ps3 controller. But not with me now if any one got the app to work with an original controller on a Samsung Transform Ultra tell me if it was just rooted and worked or if you had to use a rom
I know for a fact that it works, just follow the sixaxis controller app directions.
