desolateone1
As some of you probably know, the ps3 has recently been hacked, allowing us to run unsigned code. The source code for the exploit leaked and a dev called KaKaRoTo managed to get it to run from a Nokia N900. The other day, KaKaRoTo released his source code and someone already ported it to the Palm Pre. This quick port was possible because the N900 and Palm Pre both share the same USB controller(mUSB) which happens to be the controller used by the Droid/Milestone.
Maybe some of you guys can get this working on our milestones!
This doesn't look too hard to do either. We shouldn't need to do too many alterations to get it working on the milestone/droid.
Here is what we apparently need to do to port it from the nokia.
PSFreedom
Thanks and good luck to anyone who gives this a try!
And here's a link to the source code over at github:Well you don't really need any changes to get it compiled against Droid's kernel, a quick and dirty way by looking at psfreedom's make file:
make -C /path/to/droid/kernel/source M=/path/to/psfreedom/source ARCH=arm CROSS_COMPILE=/path/to/android_ndk/tree/build/prebuilt/linux-x86/arm-eabi-4.4.0/bin/arm-eabi- EXTRA_CFLAGS=-DENABLE_MUSB_CONTROLLER modules
PSFreedom
