smartmanvartan
Android Expert
Hello Public Mobile N860 owners...
I present to you Voltron OC BETA:
Screenshots:
Flickr: smartmanvartan's Photostream
Features:
-ADW Launcher
-swap enabled
-app2sd
-busybox
-zipaligned
-loopy smoothness tweak
-rooted
-stock tether(wifi hotspot and usb)
-Flashlight and flashlight widget
-A light system with a very complete set of apps installed as user data
-OVERCLOCKED with Glitch OC Kernel @ 1.8ghz By Downthemachine with a tweaked ramdisk by yours truly.
-TWRP Touche recovery ported by Hroark13 with file manager and terminal.
-Themed with the Voltron theme but i will be making more themes for this ROM once it is finished
-based on the Public Mobile B07 which is a newer build than Boost B08c.
-swipe and better keyboard are installed but must be activated in the language and keyboar menu in settings.
-need suggestions on a good camera app and I included the another music player( tell me which one you like)
Features to add:
-Quickpanel widget in drop down menu
-Super screenshot power menu with reboot recovery option
- A camera in the system, Have not decided on one yet, I'm open for suggestions... I have ics camera installed right now as a temp.
- Any bugs that may come about. So far this ROM is bug free
Here are the links:
*** If you have missed calls and delayed text due to the bug that occurs when screen is turned off, flash the B08 firmware but use a B07 ROM. Seems that a new bug is present with similar symptoms in the new B08 ROM, however the included firmware does effectivly fix the issue if you use the B07 system. so I have made this B08 firmware flashable for you folks... Just wipe cache/dalvik and flash with TWRP or CWM...
pmi_b08_firmware - Download - 4shared
Voltron OC Rom: pmi_n860_b07_voltron_oc_beta4_2 - Download - 4shared
If this is the firt time you install the Voltron rom on you N860, wipe everything before installing this rom. Dalvik and factory/reset(data and cache). If you are updating from a previous version only the dalvik cache and cache wipe is needed.
SMV App Pack: SMV_App_Pack - Download - 4shared
Factory Reset Flashable(use this to perform a factory reset): voltron_factory_reset - Download - 4shared
Kernels:
Glitch OC V1.2 @ 1.7 Ghz: pmi_glitch_ocv1.2_1.7ghz_smv_mod - Download - 4shared
Glitch V1.13 @ 1 Ghz: https://www.dropbox.com/s/fv2k0ghvxl21y7k/PMI_Glitch_non_oc_v1.1.3_SMV_Mod.zip
**If you dont like the awesome TWRP recovery, you can flash back to CWM with the installer in the bottom of the OP on this tread:
http://androidforums.com/public-mob.../630553-how-flash-recovery-pmi_n860-warp.html
***The tether menu although unlocked is still hidden. To access it make a shortcut on the ADW launcher by longpressing on one screen and go to the "add" tab and selecting custom shortcuts and go-to pick activity->activities->settings->settings(tether settings) and Bam! A nice little shortcut for tethering.
****The first boot takes about 4-5 min.. be patient its only for the first boot...
Special Thanks:
Hroark13 (for porting an awesome recovery and his work on the Kernel source) http://forum.xda-developers.com/showthread.php?p=32358441#post32358441
Downthemachine (for putting up with my annoying questions and making awesome kernels)
Dm47021 (For making the Alien kernel)
Dsixda(For the kitchen that does it all)
MrBobo (For putting up with my questions))
Shinru2004 (for showing me some good examples)
Jetx2x(for the same reason)
And You the user
Enjoy!
Screenshots:
Features:
-ADW Launcher
-swap enabled
-app2sd
-busybox
-zipaligned
-rooted
Features to add:
Here are the links:
Kernels:
Special Thanks:
And You the user
Enjoy!
