Pulling the battery
Lanman1978
Is this case a beyotch to crack open in order to pull the battery or what? I am used to the Triumph being a breeze to slide the back open to pull the battery. The Evo V requires patience and finesse to open.
Oh god is rather it be a female dog than it to fall off every time you put it in your pocket
Sent from my Nexus 7 using Bacon
Actually considering how well the cover stays on it removes quite easily, you should try the HTC Sensation some time, that's a b*tch!
i found that the trick to is is to use your nail to open the bottom edge, it snaps open, and instead of pulling UP on it like you instinctively want to, hold the phone on its camera button edge with the screen FACING you
run your nail underneath the now top edge between the case and the phone, youll hear it snap off another clip near the right.
once thats top you push the cover to the right with the screen still facing you.
it doesnt come off like normal covers, it has to be kind of unlocked then slid sideways out. its weird to explain but it took me a few minutes and now I can get the cover off as easily as the triumph.
the REAL problem is that you have to do a battery pull to swap SD cards. annoying. haha
edit* basically the phone cover goes OFF in the same way it goes on, you hinge the top (power button side) portion first, and you hear it seal up and snap into the phone and the fingernail slot is the last bit to connect. its the same method off, dont yank it up.
