Help Punctuation with SMS.
JoshS2
What messaging settings do I have to adjust, to be able to put punctuation like "don't" within in my SMS messages?
it all boils down to which keyboard you are using. some keyboards will support this, others won't, try in the input settings for the keyboard, if not there as an option than it probably doesn't support it. maybe an upgrade like swiftkey or swype might be the answer.
