It's the wiring. That's been an ongoing issue with USB/hardwire chargers... I had the same problem with all of my Droids, though I found by D2G charged faster on the USB charger. It was odd, to say the least.Are you using chargers that connect with a USB plug, or dedicated straight wire chargers. I've found that USB chargers struggle to keep up with the demands of the Spectrum battery. No scientific reason why, just my observation.
That is a usb charger (microUSB connector on the end).
@equest: I too had dismal battery life when I got the phone, but within a few charge / discharge cycles, things were much better. Remember, the phone must calibrate itself to the battery and that takes a few charge cycles to do.
If you root, freeze the bloatware, set your CPU Governor to Conservative, and run JuiceDefender, and things will be much better.
Will setting your CPU to conservative not affect the performance of your phone meaning it won't cause lag or speed?
It can.... But you just have to set the bottom cpu speed higher than 250 (or whatever that base number is).
I'm using lagfree, which is conservative with no startup lag.
Yep, adw lets you resize icons (within reason). It let's you change row and column numbers too. It's my fave alternate home app.
Ditto on that! Tried quite a few too. I like 5X6 then I stretch my widgets to fit.
