Root Pure Calendar BROKEN?
mitchellvii
Hey guys,
I really love the Pure Calendar (Agenda) widget. I have been running it since I got my phone with no issues. However, starting yesterday, it crashes every time I try to add it to my homescreen.
This started happening right after I tried moving it to my SD card. I have since done a full wipe and re-installed but no joy. Still doesn't work.
I'm running cm6 / Snap 7.1
Any ideas?
did you do a titanium backup/restore?
if so, click on the app and wipe data in titanium, other than that, i have no ideas
I used Astro Tools to back up. I have tried re-installing from there, and also re-installing directly from the market.
My only guess is that somehow I left some fragment of something somewhere when I tried to move it to SD and it is causing a conflict every time I try to add it to my homescreen - very annoying.
Next question - when we add apps to our SD card, where do they go? Maybe I can look and see if something is there?
Just did full wipe of everything including reformat of my sdcard. I can only guess the developer put out and update incompatible with cm6 or this kernel I'm using.
I'll flash Fresh and see if that's it.
Do you mean Apps2SD? If so, the answer is your ext3 partition. If not, look for a folder with the name of the app, the name of the dev, or the dev's company.
