Help [Q] 2.3.4 - GPS | Latitude
Ziore
Hi, since the update from 1.6 to 2.3.4 im unable to install google GPS Maps or Latitude.
Any variation or help here?
Thanks ^^
Have they been frozen in Titanium backup? I found quite a few gapps had been frozen in TB and just needed defrosting to have access again.
Ok - try this link Here transfer to your sd card and flash through recovery. It should add all the required google apps.
Otherwise you may just need to reinstall the rom again. Remember to wipe the dalvik cache before updating a rom.
I will try your link first, but, if needed, how can i wipe dalvik cache?
Searched in the forum but didn't find anything solid.
Edit: Sorry for dual post
Cleaning with Titanium gives up next message:
"Can't find innecesary files in Dalvik cache"
Just found how in titanium :P
Edit2:
Solved, searched in 4shared and downloaded Google Maps
And it's working, lets hope for no viruses T_T
