(Q) Emergency calls only?
  • Thread starter Thread starter tastycaramel
  • Start date Start date
T
tastycaramel
Guest
Hello all. I noticed that sometimes I would have emergency calls only function in an area that have signal. It would sometimes happen and I would have to repeatedly turn on and off airplane mode or restart my phone to enable the signal again.
What I want to ask is that whether this is normal or not. Even before I root my phone, this has already been happening.
Might be your SIM card beginning to fail - I had one go bad and the symptoms were the same. Getting a replacement SIM fixed it.
If you have another handset and SIM you could swap for a while and see whether the problem recurs (and if so, in which handset).
This problem first occurred around October- around the time when I finally got my Note lte! I have been using this micro sim (ex-iphone 4 user) since 2011. Was its age the cause of this problem or is it my phone?
Edit: My previous phones (Arc S and Nokia 1280) never had this problem AFAIK. On the Arc S, this problem first happened during after my examinations and it got me really very frustrated. I have to restart like twice just to get it connected.
I'm sorry for asking noob questions, but am I suppose to go down to the retail shop and request for any exchange?
Just take the phone with you and ask them for a new sim for the phone.:) They should be able to sell, replace you with a new one.:)
Currently I am using a micro sim with an adapter to my phone. Will I be able to request for a regular sim? And do I have to pay a certain fee? :rolleyes:
That depends on your network, I would think.
Mine was replaced for free, but I'd already done everything I needed together to prove it was the SIM at fault. By the time I got it done the frequency had increased from weekly to daily or less, so it was easy to test and diagnose.
I would guess I would have to fork out cash for a new sim card since 'everything is expensive in Singapore'.
Sorry for noob question but when you request for a new sim, do they diagnose your current sim?
No idea about Singapore, but in the UK, no.
If it's an intermittent fault there's no way the shop could reliably do that anyway.
Thanks. I would check with my carrier about requesting a new sim card.
Btw here's a screenshot of what happened today.
1st pic shows the weird signal bug
2nd pic shows the signal being connected after restarting the phone
