edison041078
Good day! I just get a new galaxy tab 2 10.1 but i can't watch some videos on the internet (ex. ESPN.com). It says I need to install flash player. how to install flash player. Please help! TNX!
edison
edison
Download it from the Play Store. Once it installs, you can watch flash videos. Easy as that.
Flash has been reinstated for android![]()
Just Read the Install instructions it may not work in the newer softwareI have downloaded adobe flash in my tab2 10.1(gt-p5110) last night without any problem. It is a brand new tab, just received from tesco.
Flash is working ok on the sites as well.
Hi I too have a Samsung Galaxy that had a problem gettin Adobe Flash Player.
I can not post link but you can google : download flash player archive,
then
Scroll all the way down to:
Flash Player for Android 4.0 archives
According to Samsung tech support they are working on a fix. Can I use the link above to install Flash for my Samsun Galaxy 2 ver 4.0.3?
Thanks
then
