Help [Q] Help needed and appreciated!
vista6782
Hey people!
i have successfully rooted my ERIS( thanks to you guys)..!
Now i'm currently Running CM7.2(the stable build for the eris)
The rom allows me to partition my 8 gig SD-CARD...so i partitioned it to a GIGABYTE and its running gud...!
but For some reasons i want to shift to the GIN-SEN-TAZZ rom for the eris...
it wont recognize my sd-card if i partition it!!!
help me!!!:(:(:confused::confused:
thanks in advance!!!
Why did you partition the SD card? Or, to ask the question differently, what did partitioning the SD card do for you?
Which method did you use?
Honestly, GinSenTazz wasn't a fantastic ROM - the Eris is a bit too underpowered to run that well as a daily driver. However, that's really up to you to discover - perhaps it'll be perfect for you.
Anyway, perhaps there is a way around partitioning the SD card that will help.
Also, here is a person who repartitioned his SD card and got GinSenTazz to work: http://forum.xda-developers.com/showpost.php?p=19149928&postcount=2554
Perhaps that will help...
DID not work....:(:(:(
There are lot of apps that i need in my phone and since the ERIS does not have enough internal memory...i was using link2sd in cm!!
i partitioned it with MINITOOL PARTITION WIZARD 7!!!
i partitioned it to a GIG!!
