[Q] keeping unlimited data on at&t?
hello. I'm currently using an iPhone 5 and plan on upgrading to the note 4 when its available. i have unlimited data at the moment. my question is, has anyone who was on an iPhone with unlimited data, switched to the note and was able to keep their unlimited data?
i went on at&t's website pretending i was upgrading to the note 3 and when it came to the data plan, it did not give me an option to keep my current plan. i had to get a specific data plan to continue. any help is greatly appreciated! can't wait for the note 4! :)
If it doesn't work for you and you still need unlimited, go T-Mobile. You can port your phone over easy. and unlimited single plan is only $80 a month.
I mean your best option is to go into an AT&T store and check out your options, I always do this when dealing with an upgrade or change in contract. :)
I upgrade from a iphone5s with unlimited data and went to a note 3 and was able to keep my unlimited data plan with no problems at all with AT&T, so to answer your question yes it can be done
