V SuperUser V
Android Expert
-Where in the Esteem are the LED notifications (RGB) controlled?
-What controls them?
Thanks in advance
Thanks in advance
Well, I honestly believe that the Red for charging or almost dead battery MAY be controlled by hardware but I honestly am torn between HW and SW on that one. I will take a peak around for you here soon to see if I cant manage to find it for you.-Where in the Esteem are the LED notifications (RGB) controlled?
Thanks in advance![]()
I know there's a way cuz if I use an app called light flow lite and it changes my led to cyan then there's gotta be a way
https://market.android.com/details?id=com.rageconsulting.android.lightflowlite
, so i wonder too if the app can control it i should be able to control it too. Someone wants to shed some light?Ive used it too, so i wonder too if the app can control it i should be able to control it too. Someone wants to shed some light?
I just found this article check it out
How to customize your Android phone's notification light | Tecca
read through it, it just talks about apps that allow you to customize them
k so ur didn't c this part, Android operating system doesn't have a default way to adjust the light's colors and notifications to make it more personalized.
i did...let me put it to you this way, for example when a sms comes in a blue LED lights up, something inside the phone tells the LED blue to turn on when an sms arrives, i want to know what that something is....perhaps there is a way to tell the LED to flash on and off when an sms arrives![]()
no, you nailed, it, i havent ask any devs thoughhave you tried asking one of the devs to those apps what was used in order to control the light? directory, file, etc? once you find out you can go from there?
or am i missing something else?
Don't know if this helps but: Go SMS pro has the option to change the lights under notifications: color and blinking rate
thanks bro, but im looking for the place inside the phone where Go SMS goes and changes the phone's LEDs
