Help [Q] Net10 Help!
2010gleek
Anyone able to get MMS working on Net10?
I have:
Data (H+)
Sending MMS
Text
Calls
Dont:
Receiving MMS
The APN I'm Using Is:
APN: tfdata
Proxy: Not Set
Port: Not Set
Username: Not Set
Password: Not Set
Server: Not Set
MMSC: http://mmsc.cingular.com
MMS proxy: 66.209.11.32
MMS Port: 80
MCC: 310
MNC: 410
Authentication Type: Not Set
APN Type: default,supl,mms,hipri
APN Protocol: IPv4/IPv6
APN Roaming Protocol: IPv4/IPv6
APN enable/disable: Enabled
Bearer: Unspecified
... The APN I'm Using Is:
APN: tfdata
Proxy: Not Set
Port: Not Set
Username: Not Set
Password: Not Set
Server: Not Set
MMS Port: 80
MCC: 310
MNC: 410
Bearer: Unspecified
MMS was previously working for me, but I lost data connectivity early last week, and after 3 days was given the following APN, and the support person told me she had to "reset data" on my number. The MMS I've tried to send the past two days has repeatedly failed though.
The APN I'm now using with MMS failure is:
APN: wap.tracfone
Proxy: proxy.mvno.tracfone.com
Port: 80
Username: Not Set
Password: Not Set
Server: Not Set
MMS proxy: mms2.tracfone.com
MMS Port: 80
MCC: 310
MNC: 410
APN Protocol: IPv4
APN enable/disable: Enabled (grayed)
Bearer: Unspecified
I've become considerably disenchanted with net10 service after 3 months, especially after being informed that the "unlimited" data plan I purchased through 23 Mar. using an AT&T SIM will be limited to 1.5 GB come 01 Mar. Grrrrrrr .... I requested the net10 T-Mobile SIM which is still "unlimited", but it appears that T-Mobile service in my remote area is only "Edge" 2G, and marginal at that. At least the AT&T 3g was HSPA:10, but 1.5 GB for 30 days is totally inadequate for my professional needs.
APN: wap.tracfone
Port: 80
Username: Not Set
Password: Not Set
Server: Not Set
MMS Port: 80
MCC: 310
MNC: 410
APN Protocol: IPv4
Bearer: Unspecified
Sadly that APN doesn't work for me at all even data doesn't show up :-/ I seriously about to just jump ship to AT&T, tmobile sucks here in KY.
