Help [Q] Problems with my HTC DESIRE
kmetek
Member
I can't find similar threads because i don't know what the problem is.
SLOVENIAN:
Včeraj do večera vse ok. Danes zjutraj pa nekaj začel biksati:
Force close sem moral LAUNCHER PRO in pa WIDGETLOCKER kot "home screen"....ugasnem, pri
Do you have titanium backups / nandroid backups?
If so, backup card contents, flatten the card (remove partition and format card to new state), mount in recovery on your PC and download / run h2testw application:
Download H2testw 1.4 Free - Check your USB for errors with this tool. - Softpedia
This will check card for errors. If no errors, repartition the card using Gparted Live CD and copy contents back over. Resture either a nandroid or titanium backup
Boot into recovery (see rooting faq) go mounts and storage menu if you have clockwork and then select mount as usb mass storage
