Root [Q] Soft Keys
I'm running CM7 TG- Reloaded and the soft key buttons aren't lit up. Is that normal?
i dont believe this is normal, im running the samething and my buttons are lighting up, altho they are alot dimmer then they are on stock, which i dont mind, cause itll save my battery
You can try
settings > profiles > default
In the application groups select each of the groups and click on lights mode set it to on/off whichever you want/need
been awhile since I messed with this, hope it helps
