Modern Chinese production is of very high quality...
only buy from a US sellers that test and mods them to work right and offers a good long warranty like FLsuperstore.com
elated with my china tab
FLss has the Eken T01 now which is a tad better with a full size USB port, but is the same tablet. Frank is a great guy to deal with and johnny on the spot to answer questions.
use this code for a %5 discount "SLATE"
[I got the T02 as I was in a hurry and didn't want to wait for the T01 to come in and I didn't need full size USB. But its the same tablet.]
It will be the best $100 you ever spent.
He is very honest when he says that the T01 is better then most of the other tablets he sells for more and I would agree 100%.
7" Eken T01 Android 4.0.3 ICS 4GB Allwinner A10 Cortex A8 Tablet PC Full Market
I need your opinion on tablet pc android made ​​in China.
My question, does the same quality from other countries .. made ​​from the U.S.??
I have to concur with Mikedt. Buy local, from a source where your money and your consumer rights are protected. The Chinese market is saturated with copycat companies that operate almost sweatshop factories producing products that, on the surface, appear to be the same as more expensive and competing products. However, the quailty and source of the components and assembly can be, literally, garbage; with no potential to upgrade the firmware even if it works more than six months. Hence the advice to buy from a source where your purchase is protected.
I live in China and bought an Onda - one of the upcoming Chinese brands. It crapped out, and the replacement was DOA - so far 5 weeks and counting; probably at least another two weeks before they supply another replacement - and that's with an official receipt from an official reseller dealing direct with the factory! You get what you pay for and, in China, often less.
David.
^ except everything is made in China, even the so called name brands. crack one open and research where the PCB parts came from.
Trouble with the name Onda, sounds too much like Honda, especially when said by cockneys "Bought a used 'onda from a geezer in a pub....only cost me a monkey...good innit?"
BTW I kind of like how the words "Quality Android Tablet" and "China" sit together in thread's title. It's rather an oxymoron I think.
Agreed. However, there's a world of difference between a foreign built and controlled factory and a Chinese one. Quality control in raw materials, design, and production is of a very high standard and that's why they usually cost more.
The Chinese copycat factories will resource "b" and "c" grade components - whatever is cheapest this week - and sling them into an assembly workshop with absolutely no concern about anything other than shifting product.
It's a fascinating country to live in and, for my part, a very complex and often frustrating experience, but an experience worth having.
David.
